Description from their European website, in case you thought they weren't "
high-fidelity" enough!
'A' for the effort to sell these, (or is it 'E' for effort?)
lii-audio-europe.com
Catálogo Lyric Altavoces
There are a few key things that people look for in
high-fidelity speakers for home use:
- Sound quality: High-fidelity speakers are designed to deliver accurate, lifelike sound. This means a wide frequency range, low distortion, and a balanced, neutral sound.
- Power handling: High-fidelity speakers need to be able to handle a wide range of power levels and dynamic range, so they can reproduce everything from quiet whispers to loud explosions.
- Build quality: High-fidelity speakers are often made with high-quality materials and careful attention to detail. This helps them deliver the best possible sound quality, but it also means they can be more expensive than other types of speakers.
- Compatibility: High-fidelity speakers should be able to work with a wide range of audio equipment, including amplifiers, receivers, and source components. They should also be able to handle different types of audio formats, such as analog and digital.
- Aesthetics: Finally, many people look for high-fidelity speakers that look good in their home, whether that means a sleek, modern design or a more traditional look.
