Absolute Phase
Guys,
On this wonderful day with the blessing of Shirdi Sai baba, Absolute Phase is happy to announce that we have been appointed as the Sole India Distributor for Airtight Valve amps. These amps are handcrafted in Japan and are the Rolls Royce of Japanese amps and are known worldwide.
In 1986 when the audio industry was in the midst of chaos losing its original peerless dream in the general shift from valves to transistors, our A & M Ltd. was founded with ardent wishes to create such products that provide full listening pleasure to all music lovers and audiophiles, thus enabling them to form an increasing attachment by repeated listening.
The philosophy is crystallised, through an exhaustive research and development, in the AIR-TIGHT branded audio gear featuring refined cosmetics, strictly select components, PCB-free point-to-point meticulous hand-wiring, etc.
The ultimate award is the infinite musicality that extends far beyond mere specifications, approaching the sublimate soundstage presentation, in full depth and width, of live performance.
Small as A & M is in size, we keep on giving a challenge for realisation of our grandiose dream. Have a startling experience to enjoy the second-to-none musicality only our time-tested valve configuration affords!
On demo we have the following Airtight valve amps:-
1. AIRTIGHT ATC-1 PRE-AMP
SATISFACTION OF CRAVING FOR PAST WITH MODERN TECHNOLOGY
Highly reliable 12AX7 valves meticulously selected after ageing
3-stage low-impedance K-K NF configuration equaliser acclaimed for low distortion & wide frequency response
Simple, single-stage flat amp for pure sound
High-voltage B-power supply with quick recovery diode
PCB-free hand wiring
Discrete, highly rigid dia-magnetic chassis
EL-core power transformer
Valves employed: 12AX7(ECC83) 5
Output voltage: rated 2V, max. 15V
Output impedance: 600 ohms (pre-out, EQ-out)
THD: 0.05% (phono), 0.02% (line)
Input sensitivity: phono; 1.8mV(output 1V), line; 150mV (output 1V)
S/N ratio: less than 85dB (phono) & 98dB(line)
Dimensions: 430(W) 325(D) 90(H)mm
Weight: 7kgs
Weight: 7kgs
