Any one in chennai to help build an amp
Looking to build a 300w amp for my towers. Any one in chennai to help with the same
If you are looking at building one from scratch then consider this website
Simple designs, simple instructions. Not very expensive to build
There are lots of experts here whom you could ask their opinion on the design and performance
Ever since the main contributor and designer of the circuits died, many bare boards from this website are available in the Delhi and Calcutta market as well as fully populated ones.
I was building this one. But soft start, zobel, speaker protection, preamp etc are to be built separately.
But covid has put a temporary stop to it
There are superior designs available here on this site and maybe you should consider those.
Best of luck
