I use the 8006 duo. ND8006 is a huge step up from my previous 6005, but at 3 times the price that is expected. Spotify Connect is a breeze. No need to use Heos. You can output the system to either a power amp directly or to an integrated amp. Build quality solid Japanese.Hi Friends,
Wanted to know if anybody is using marantz NA6006 streamer? or the ND8006 which is a streamer + CD player.
amit11.
Thanks.I use the 8006 duo. ND8006 is a huge step up from my previous 6005, but at 3 times the price that is expected. Spotify Connect is a breeze. No need to use Heos. You can output the system to either a power amp directly or to an integrated amp. Build quality solid Japanese.
Also now it's 15 K cheaper compared to what I paid :-(
Any specific questions?
I use a Marantz NA8005 streamer which I am assuming is in the same category as ND8006. Sound quality is very good while streaming and as an independent DAC. The main issue is the primitive user interface for streaming.(this could be an older product I guess).Thanks.
In terms of only streaming and sound quality, which one would be better. The ND8006 or NA6006? I mainly want to use the airplay functionality with my ipad. I do not have any CDs.
ND8006 which has CD player also is slightly more expensive than the na6006, but if it has better sound quality then would it be better to buy that?
If you do not own any cds and also do not plan to build a collection in future, then the Cd section is wasted. If your primary purpose is only going to be streaming as you mentioned, then imo it does not make sense to spend double the amount for the Nd8006. The improvement in sound quality may only be marginal.I do not have any CDs.
Hi,I use the 8006 duo. ND8006 is a huge step up from my previous 6005, but at 3 times the price that is expected. Spotify Connect is a breeze. No need to use Heos. You can output the system to either a power amp directly or to an integrated amp. Build quality solid Japanese.
If you have raspberry pi, install shairport sync. I use my PIs connected using ethernet cable. No issues with connectivity break, buffering, etc. Even with my bananana PIs on wifi there isn't any connectivity break, just that it takes 2-3 seconds extra first time.Hi,
During streaming do you face any occassional connectivity breaks?, and have you used apple airplay with it because my main use would be with apple airplay.
IIRC, NA6006 shares the same electronics with ND8006. Same DAC too. Only the CD Drive is missing. You may want to double-check this. In that case, sound quality should be identical. Though there would be a huge difference in the build quality, I don't know it's impact on sound.Hi,
I just checked. NA6006 is discontinued. One site in India is offering at a ridiculous price. Just forget about it. Grab the ND8006 in a heartbeat if you like it. You won't regret for a moment.Hi Friends,
amit11.
Thanks.. yes somehow i am also leaning towards ND8006, even though i do not have CD or it may be expensive than na6006.I just checked. NA6006 is discontinued. One site in India is offering at a ridiculous price. Just forget about it. Grab the ND8006 in a heartbeat if you like it. You won't regret for a moment.
