Arrival of my power house
bhavin.patel
India
Hi Friends,
Had received my power house just couple of hours ago. Thanks to this forum where I was able to meet like minded peoples.
Brief review of these speakers would be done once I receive my AVR and connect them with it. Subwoofer and surround speakers would added step wise as my budget has been completed with this purchase.
I cross my fingers that they sound well at my home as I dun be having budget of acoustic treatment currently.
BR//
B Patel
Are these psb imagine X2T?
What are your room dimensions bro
These are older version PSB Image T6. My room is 14*13*12.
Yes I know this combo is over kill for my room size, though I am having wonderful time with these FS. Will post my detail review soon.
BR//
Bhavin
BR//
Bhavin
Hi bhavin
I also happen to have almost similar room size..
What do you suggest ... Should i go fir x2t or a bookshelf
Btw i loved psb x2t when i demoed it but i just think whether it will we too much for my room i.e 12*14
PSB XT2 is excellent speakers. Yes it be surely overkill for our room size though you will love the way it sounds in your room. I used Audyssey XT Pro calibration for my room setup and bro I tell you that it has done magic.
I will recommend to go for X1T as it will also suffice your needs. Balance amount can be used for acoustics of room.
BR//
B Patel
