Marantz ND8006 is also one option. Price wise it is much lesser than your budget. I got one recently. It also has a CD player in it.Looking to buy this 3 in 1 device with budget about 3.5L
If same device has internal storage to store my High Resolution Audio files that great
Please help me in suggestion that I can buy in India or UK
Thank you,
~Vijay
Thanks Amit,Marantz ND8006 is also one option. Price wise it is much lesser than your budget. I got one recently. It also has a CD player in it.
Hi Vijay,Thanks Amit,
Marantz ND8006 seems good option... however I'm not sure if it comes with it own App? I really do not want get into Roon to add reoccurring cost. I will prefer to use my iPad mini as a device to control playlist, Tidal and other streaming services via single app
BTW do you mind sharing your price that you purchase recently and where?
Thanks...Naim Uniti Atom
Uniti Atom
The new Uniti Atom by Naim Audio is our compact, high end all-in-one player with outstanding sound quality & an array of exciting features. Learn more here.www.naimaudio.com
Thank you...In my opinion - (In NO order of preference)
Cambridge Edge NQ - Does everything you want, but higher than your budget atleast in India.
HiFi Rose products - for all you want to do including internal storage
AudioLab 6000n - though no external disk support & a painful app when tested 2 years ago.
Naim Unity Atom (NAIM makes a couple other horrendous looking but great performing products)
BS Node 2021
***These are the ones I am aware of, used or researched.
There is a headphone version of this which doesn't have the amp stageThanks...
I will have to ignore its Amp capabilities and use pre-output. Also I will save some INR from my budget
which model is that?There is a headphone version of this which doesn't have the amp stage
The NAD Masters Series M10 V2 should definitely be on your shortlist.Looking to buy this 3 in 1 device with budget about 3.5L
Thank you,
~Vijay
You have the added advantage of Room Correction via Dirac Live.
https://www.crutchfield.com/S-1c6dS2Dfn6q/p_745M10V2/NAD-Masters-Series-M10-V2.html
Hows ND8006, i got NA8005 for 70kMarantz ND8006 is also one option. Price wise it is much lesser than your budget. I got one recently. It also has a CD player in it.
