HotDEAL Audio Technica AT-LP60X Fully Automatic Belt-Drive Turntable
HiFiVision
Super Moderator
Audio Technica AT-LP60X Fully Automatic Belt-Drive Turntable for ₹21,800.00
The Audio Technica AT-LP60X Fully Automatic Belt-Drive Turntable is a high-quality, reliable, and user-friendly turntable that's perfect for both seasoned audiophiles and those just getting into vinyl. With its sleek, modern design and intuitive controls, this turntable is perfect for anyone who wants to enjoy their favorite records with ease.
Featuring a fully automatic belt-drive system, the AT-LP60X makes it easy to play your vinyl records without the hassle of manually positioning the needle or adjusting the speed. The turntable also comes equipped with a built-in phono preamp, which allows you to connect it directly to your stereo system or powered speakers without the need for a separate pre-amplifier.
The AT-LP60X has a die-cast aluminum platter that provides a stable foundation for your records, and the included Dual Magnet™ phono cartridge with replaceable stylus ensures that your music sounds as clear and vibrant as possible. The turntable also comes with a removable dust cover to help protect your records from dust and debris.
The AT-LP60X supports both 33-1/3 and 45 RPM playback speeds, so you can enjoy all of your favorite records regardless of their format. The turntable also features a switchable phono/line output, which allows you to connect it to a variety of different audio systems with ease.
Whether you're a longtime vinyl collector or just starting to explore the world of analog sound, the Audio Technica AT-LP60X Fully Automatic Belt-Drive Turntable is an excellent choice. With its ease of use, high-quality components, and versatile features, this turntable is sure to provide many years of listening enjoyment.
