Hello
Here are some lovely supports for speakers as well as electronics.They are invaluable to those who have no space for racks and stands and would like a wall mountable solution, and yet require the mount to be well made and rigid and vibration free.
They are imported from the following manufacturer. However since we are the sole importers prices are surprisingly reasonable.
Solutions For Other Products | OMB Italy
AudioMagix
This is a really well made solution for wall mounting electronics that are heavy or require good support as well as isolation.The audioMagix is affixed to the wall using 6 extra long screws and the expansive arms provide ideal support with NO springboarg effect ( which is experienced by many brackets that are commercially available).
It is ideal for wall mounting Turntables , Amplifiers, AVRs etc
Isolating and antiskid neoprene inserts provide a firm grip to the shelf (which either the customer can procure or we can send - or alternatively you can even go shelfless!! ).A Fibre outer cover hides all the ugly mounting screws as well as allows a pass through for cables
The mount is finished in a durable antirust matt black coat (Please note the picture however shows a silver finish and is only for illustration)
For someone who has more equipment one can easily mount one audiomagix below the other. The fibre cover giving it a sleek oem look
Note: commercial wall mount supports are available however these are bracket based supports that do not support more that the weight of a DVD player. Their shelf support area extends only to a couple inches due to which a springboard effect is inevitable and due to which it also becomes unsafe when mounting heavier and larger sized loads.
Specs
Will support equipment upto 30 inches wide
Will support equipment upto 20 inches deep
Will support equipment upto 30 kgs weight
Ideal for
AVRs, Amplification, Centre speakers
Bimagix 30
This is well made wall mount that will support speakers weighing upto 30 kgs
A steel swivelable mount that has a fibre cover on both the extending arm as well as the wall mounting plate, this mount combines superb support with top end aesthetics and is well at home in well furnished living rooms.
Both the arm and the top plate can be swiveled. Internal cable mangament allows you to hide the wires behind the fibre covers.
The mount is finished in a durable anti-rust matt black coat (Please note the picture however shows a silver finish and is only for illustration)
The USP of this mount is its fit and finish as compared to most locally made flimsy welded wall mounts. Being an Italia product
AudioMagix
Specs
Ideal for
Bimagix 30
