Avr dilema
RAJUSH26
pimpri
hI FRIENDS PLS SUGGEST FOR THE BEST AVR AMONG THE BELOW:
YAM 473
YAM 671
@ ~350 GBP
:clapping:FRIEND GETTING IT AT UK PRICES:clapping: , CONSIDERABLY LESS THEN INDIA,
WILL THERE BE A PROB IN CUSTOMS.
if total items cost is within 25k I think..there wont be any problem..otherwise not a very big deal..simple negotiation with customs....and a bargain rate of duty/taxes
YAM 473
YAM 671
@ ~350 GBP
depends on what you need. Do you plan to buy simple satellite speaker set then 473 is sufficient, if you are planning for floorstanders then I would recommend 671.
personal suggestion is 671 :)
