I have Boston Acoustics Digital Cinema system.
When I shifted recently, the speakers got damaged and I need to replace them.
Can I replace the Soundware XS speaker that came with the system with the larger Soundware speakers?
I have put the comparison specs from the website below.
Dig Cin Sat Soundware XS Soundware
Frequency Response 150Hz 20kHz 150Hz 20kHz 90Hz-20kHz (3dB)
Recommended Amp Power 10 100 watts 10 100 watts 15 100 watts
Nominal Impedance 8 ohms 8 ohms 8 ohms
Sensitivity 85dB [SPL/2.8v at 1m] 85dB [SPL/2.8v at 1m] 87dB
Woofer 2 (64mm) 2 (64mm) 4 (114mm)
Tweeter (13mm) (13mm) (20mm)
Crossover Frequency 4kHz 5kHz 3.5kHz
Dimensions: (H x W x D) 4 5?16 x 4 1/2 x 3 3/4 4 5?16 x 4 1/2 x 3 3/4 6 1?6 x 6 1?6 x 6
I am a newbie and I thought that with the same 8ohm impedence, maybe I could upgrade to the better speaker.
I am not a big audiophile. The system is used primarily to listen to music from TV / youtube / bluetooth, and also to add some surround sound when watching HD movies on cable TV.
Can I do the upgrade and will it be worth the ~$20-30 difference in price (per speaker)?
Thanks for your help.
