"Good" is subjective. If you are going to play original BDs, all known brands are good. If you are looking at DVD upscaling then the models in the 10-14k range are better. The higher end ones will be 3D capable as well. Finally there is a budget to be considered. BDPs start from 8K to 20K. Sony PS3 is unique because it doubles up as a gaming console as well. Whatever is said above with Indian context, holds true for foreign players as well except that there are much wider choices. State your needs, budget, etc. and then a BDP can be suggested.
The only players sold in India that can be made region free are Panasonic BD players.
