Rupam
I have forsaken the idea of HtiB and now looking for AVR + 5.1 speaker.
I would like to make a comparison between all the budget receivers and then ask your opinion about them. As I know here FM have much more experience with AVRs, they can point out the specifications which looks good on brochure and which do matter in real listening condition.
As far my needs are concerned I need to clarify them because the comparison will be based on them.
I like bright sound as long as it does not cause ear fatigue and also need an AVR which can create big sound-stage. I like bass, as long as it stays low and don't cloud the mid-range.
Now the receivers which are available currently in the market in this budget:
DENON AVR-1612
Price Rs 26,000.00
Decoders
1. Dolby TrueHD
2. Prologic IIz
3. dts-HD MA
Amplifier
Audyssey MultEQ and Auto Setup
Audio Return Channel
NO Video upscale
Ports In
HDMI x 4
S-Video x 1
Composite (Video) (included front 1) x 3
Analog Audio (included front 1) x 4
Digital Optical x 1
Digital Coaxial x 1
Ports Out
HDMI Monitor x 1
Composite Monitor x 1
Audio Preout 2.1 ch
(Surround Back / Front Height (L/R), SW)
Phones x 1
Other
USB port x 1
Dock Control Port x 1
FM Tuner Antenna x 1
AM Tuner Antenna x 1
Microphone port x 1
Other Features >
YAMAHA RX V373
Price Rs 28,990.00
Decoders
Dolby TrueHD
DTS-HD Master Audio;
Dolby Digital Plus and DTS-HD
Amplifier
5-channel 500W = 100W x 5 (6 ohms, 1 kHz, 0.9 % THD)
192 kHz/24-bit Burr Brown DACs for all channels
High dynamic power, low-impedance drive capability
(8/6/4/2 ohms)
Compressed Music Enhancer
YPAO sound optimization
Deep Color/x.v.Color/24Hz Refresh Rate /Auto Lip-Sync
Ports outs and ins
HDMI Input/Output --4 / 1
USB Input iPod/iPhone, USB Memory, Portable Audio Player
Front AV Input -- USB/Mini Jack/Composite
Digital Audio Input/Output: -- Optical 2 / 0
Digital Audio Input/Output: -- Coaxial 2 / 0
Analog Audio Input/Output -- 4 (front 1) / 2
Component Video Input/Output -- 2 / 1
Composite Video Input/Output -- 4 (front 1) / 1
Preout-- Subwoofer
Headphone -- Output 1
Other Features >
4K pass-through for next generation (for my son perhaps if he uses )
9 selectable subwoofer crossover frequencies
Yamahas exclusive CINEMA DSP
_________________________________________________________________
Marantz NR1402
Price Rs 24,500.00
Decoders
HD Master & High Resolution Audio/ES/96/24/ Discrete & Matrix6.1/ Neo:6
Amplifier
Audyssey MultEQ
Pure Direct / Source Direct
Learning, Precode Remote Control
Ports outs and ins
HDMI In -- 4
Component In -- 2
Composite In -- 3
HDMI Out -- 1
Component Out -- 1
Composite Out -- 1
AUDIO
Analog L&R In -- 4
Digital Optical In -- 1
Digital Coaxial In --1
Pre-Amplifier Out 2.1
Flasher In/IR Receiver In/Emitter out 1/0/0
Front Panel A/V Inputs 3.5mm mini jcak (L/R) for Portable Audio Player etc.
Headphone Out 1
M-XPort allows audio playback from Bluetooth-enabled devices
Other Features >
Slim design with half the height of traditional receivers. (really sexy )
2.1 channel preamp output
Lip-sync (digital audio delay) 0-200 msec
9 Band EQ, -20dB - +6dB
Pioneer VSX - 821-K
Rs 29,000.00
Decoders
Dolby True HD
Dolby Digital Plus
Dolby Pro-Logic IIz
DTS-HD Master Audio
Amplifier
Power Output Per Channel (1kHz@6ohm) 125 W
Digital Core DSP Engine Texas Instruments Aureus
DAC 192kHz / 24-Bit
Music File Playback 48kHz / 16-Bit MP3, WMA, AAC Via USB
5-Band EQ
Phase Control
Advanced Surround 9+1 Mode DSP
NO audyssey Less known Multi-Channel Acoustic Calibration System :indifferent14:
Ports outs and ins
HDMI Input / Output -- 4 In (Rear) / 1 Out
Bluetooth Adapter Port -- Optional AS-BT200
Component Video Input / Output -- 2 In (Assignable)
Composite A/V Input / Output -- 5 In / 1 Out
iPod/ iPhone / iPad -- Yes (USB+V)
Front USB Memory Input -- 1 (Front)
Analog Audio Inputs / Output -- 2 In / 1 Out
Digital Inputs / Output -- 1 Coax / 2 Optical (Assignable)
Pre-Amp Output -- 2.1 Ch (SW, SB/FH)
Headphone Output -- Yes
Front A/V Inputs -- USB / AV Inputs
Other Features >
VSX-821 is compatible with iPod, iPhone devices and are specifically designed to enhance the experience you get from them. (I don't use Apple)
Now lets have a look at their butts >
DENON AVR-1612
YAMAHA RX V373
Marantz NR1402
Pioneer VSX - 821-K
Now given my preferences, what do you guys suggest, which AVR will be most reliable for me?
This will be a long term investment for me, say 6-7 years. So durability will be considered along with sound quality.
- My requirement is 80% Movie and 10% TV and 10% Music.
- My room size is 12X14
- I will be using satellites or bookshelves, NO floorstanders
- Network features and Apple compatibility is not required
- Audyssey or any other proprietary auto sound calibration is a must.
- Zone 1 Zone 2 is not mandatory but is a welcome feature
- USB playback
DENON AVR-1612
Price Rs 26,000.00
Decoders
1. Dolby TrueHD
2. Prologic IIz
3. dts-HD MA
Amplifier
- Fully discrete, identical quality and power for all 5 channels (120 W x 5 ch)
- (6 ohms, 1 kHz, THD 0.7%)
- Minimum Signal Path for clear audio and video signal
- Compressed Audio Restorer to enhance digital music files
NO Video upscale
Ports In
HDMI x 4
S-Video x 1
Digital Optical x 1
Digital Coaxial x 1
Ports Out
HDMI Monitor x 1
Audio Preout 2.1 ch
Phones x 1
Other
USB port x 1
Microphone port x 1
Other Features >
- Audio Delay function (0 to 200 msec)
- Muting level settings (Full/-40dB/-20dB)
- Variable subwoofer crossover switching
- Lower power consumption at stand-by 0.1 W (Standby)
YAMAHA RX V373
Price Rs 28,990.00
Decoders
Dolby TrueHD
Amplifier
(8/6/4/2 ohms)
Ports outs and ins
Preout-- Subwoofer
Other Features >
Marantz NR1402
Price Rs 24,500.00
Decoders
Amplifier
- Power Output (8 Ohm) 50W (20Hz - 20kHz, 0.08% THD, 2ch driven) x5
- Discrete Amplification for all channels
- D/A Conversion 192kHz/24-Bit
- Variable X-over
- No Video up conversion
Audyssey MultEQ
Ports outs and ins
HDMI In -- 4
Component In -- 2
Composite In -- 3
HDMI Out -- 1
Component Out -- 1
Composite Out -- 1
AUDIO
Analog L&R In -- 4
Headphone Out 1
Other Features >
Pioneer VSX - 821-K
Rs 29,000.00
Decoders
Dolby True HD
Dolby Digital Plus
Dolby Pro-Logic IIz
DTS-HD Master Audio
Amplifier
DAC 192kHz / 24-Bit
5-Band EQ
Phase Control
Ports outs and ins
Other Features >
DENON AVR-1612
YAMAHA RX V373
Marantz NR1402
Pioneer VSX - 821-K
