Best HT Setup Suggestions Reqd.
India
My room size is 12 / 12 feet in size. Please suggest best HT setup that will be appropriate for this room size. What RMS is best for this kind of room size. I have got 32" Sony LCD. Will be attaching my HT Setup with it. Also which amp/av receiver/preamp would be best for that setup. My budget is around 1.5L for now but maybe i can upgrade the components in near future when i will have more money. Help reqd. from my fellow forum experts and members. Thanks to all in advance for helping and giving your valuable time and suggestions for answering my query.
It would much better, if you could at least select some of them and then somebody can comment on the equipments that you have selected like
Eg:
AVR : Onkyo 709, 609, Denon 2113, Marantz 5005, yamaha 667 ..etc
Speakers : MS Aviano , Wharedale 9.1, BA ,Sonodyne..etc
You can give some more details like proportion of movies/music/games which you intend to use with this HT setup. For a room of 12x12 5.1 should be sufficient. However you can get a AVR that support 7.1.
Following are some options
Denon 2113 - Rs.50000(approx)
Marantz SR6006 - Rs.58000(approx)
Marantz SR5006 - Rs.50000(approx)
Pioneer VSX-1122K - Rs.50000(approx)
Yamaha RX-A820 (Aventage Series) - Rs.75000(approx)
Also look for Pioneer Elite Series AVRs
5.1 Speakers
Paradigm Cinema CT100 - Rs.55000(approx)
Q Acoustics 2000 Cinema 5.1 - Rs.65000(approx)
Q Acoustics 7000 Lifestyle Cinema 5.1 - Rs.70000(approx)
Mordaunt Short Alumni 5.1 - Rs.80000(approx)
IMO, 7.1 and Tower speakers could be over kill for 12x12 room.
Thanks for the suggestions Jeyaraj Sir. I will check out some components and paste them here after i will visit the shops and check out the demos.
