K karthickchelvan New Member Joined Feb 13, 2012 Messages 7 Points 1 Location chennai, india Aug 9, 2012 #1 im having 7 devices totally.. suggest me a good universal remote.. budget strictly 4k.. thank you
baijuxavior Well-Known Member Joined Mar 7, 2011 Messages 4,392 Points 113 Location Kerala Aug 9, 2012 #2 I think Logitech Harmony 525 can support upto 10 devices. The battery life is very poor. Use rechargeable battery.
T tma Active Member Joined Sep 25, 2009 Messages 150 Points 28 Location Bangalore Aug 9, 2012 #3 I doubt you would get one that controls all 7 in that price range. Have used One4All and Logitech Harmony that can control up to 4 devices. These are around 2.5-3k. I found one4All a little better but logitech can be programmed via the usb port.
R ravikumar615 New Member Joined Mar 16, 2011 Messages 91 Points 0 Location Bangalore Aug 9, 2012 #4 Logitech Harmony 650 is 4.2k but I think it can support only 5 devices ... marginally above your strict budget You can also try One4All 7960 around 1400/- I think it supports 6+3 devices Last edited: Aug 9, 2012
W wingryder New Member Joined Aug 10, 2012 Messages 3 Points 0 Location india Aug 16, 2012 #5 are these capable of controlling appliances like ac
