I've decided not to purchase the NAD 165BEE though it's probably a better combo than the NAD 372. Do you think the NAD372 will take away sound quality of the 275BEE? After reading several post, it sounds like the 275BEE is more musically sound and the 372 is much flatter.
Well Roddy, even though the power rating of the C372 & the C275BEE are same in terms of wattage, the circuit design & the power supply design differ from each other. There are more chances of difference in output levels between the two of them. Also, in most cases a dedicated stereo preamplifier's sound quality is much better than the preamplifier section of any integrated amplifiers.
So I strongly recommend to go for one NAD C165BEE preamp & two C275BEE power blocks for a clean & perfect bi-amping.
It is not clear how you are going to do it. Does the pre-amp have two pairs of outputs, one for each power amp?
Yes it has two pairs of outputs. 1 fixed level output & 1 variable level output.
Remember: For bi-amping with two identical power blocks, the Volume(db) level of variable output should be kept at '0' ... means full level ... so that the output gain levels of 1 & 2 becomes the same.
Reason for designing the output 2 as variable:
1) This will be helpful while using two power amplifiers which are not identical in terms of power (wattage).
For eg: If there are two power amplifiers ... say one with a higher (150 RMS) & one with a lower wattage (100 RMS), the lower wattage power amplifier has to be connected to output 1 (fixed) & the higher wattage power amplifier has to be connected to ouput 2 (variable) & the gain level has to be adjusted to match the power of the lower wattage power amplifier.
2) If needed, a SUBWOOFER (Active or Passive) be connected to this output.
In case of an active subwoofer the gain level can be set to '0' & the output level of the subwoofer can be fine tuned to match the MAIN speakers by adjusting the volume control of the active subwoofer (in most of the subwoofers the control will be on the rear side).
To connect a PASSIVE subwoofer an additional stereo or a mono power amplifier is required. In this case, the gain level has to be adjusted on the preamplifier to match it with the MAIN speakers.
For those who are not aware of the difference between Active & Passive subwoofers.
Active subwoofers include a built-in amplifier with various controls & Passive subwoofers have a subwoofer driver and enclosure and they are powered by an external amplifier.
Rear images of NAD C165BEE Preamplifier, An Active subwoofer, A Passive subwoofer:
