Big TV component output audio problem with Thoshiba L3300
bobin
kerala
I have Reliance Big TV STB and Thoshiba 32 inch L3300 TV .When it connect on component video format only video is available but no sound out put is coming from TV is it the problem of STB or TV ,please Help me
Component Video (Red/Blue/Green) is only meant to pass video signals and these are supposedly the best and purest form of video signals. You would need to connect another pair or RCA cables for audio. Please refer to the Toshiba operations manual for setup and you will definitely find the answer.
You may want to adjust the settings for the setbox once all connections are done to ensure optimal performance.
Because component out is suppose to carry video signals only
With hdmi audio and video both are transferred together
In addition to the 3 wires(red, blue, green) to carry video signal you need to connect 2 more wires (red and white usually) to carry audio from set top box fo TV
