StillWaters
Hi Folks,
I just bought a Sony 40EX650 from Ghaffar Market in Delhi. The cost was Rs. 42500. I am really happy with the purchase and want to set it up correctly for maximum enjoyment.
I request the helps from resident experts on this forum to help me with the following 4 queries:
1) Do I need a Voltage Stabilizer with the TV? If yes, which kind CVT or Automatic Voltage Stabilizer? Also what should be the rating of the Stabilizer?
2) Is there a break in procedure for the TV or can I just start using it as it is?
3) What is the correct picture and color calibration method for this TV? I tried a Xvid movie and the color seemed duller than what I used to see in showrooms.
4) Is there a way to check the usage period of the TV? Just want to make sure that its a fresh piece
I'll post a review once I have fiddled around with the TV and used it for a few days.
Thanks for your help.
StillWaters
StillWaters
