Buying a Projector for the first time ever!
machinfinity
Pune
As many have pointed out here in the forum, projectors have a lengthy learning curve and it will be nice to start with an entry-level model.
I had initially planned to get a Full-HD LED projector after generating enough funds, but my father's birthday is just around the corner and he is a huge Cinephile, so planned to get a Cheap Entry-Level model just in time to gift him. Please suggest an option that will be as per my requirements given below:-
Budget: 7k.
Source: Amazon FireTV Stick / Bluray Player. Usage is mostly 1080p movies.
Projector Distance from Screen: 16 Feet.
Options Checked through Forum Threads & Amazon Listings:- Egate i9, UNIC 46.
As far as i understood, there doesn't seem to be a real contender to the Egate i9 at the intended price point. The UNIC models are also a great option but i am not sure about after sales support. Should i get a projector screen online or DIY option will be relatively cheaper?
I am a complete noob when it comes to Projector Screens and Projectors in General, so please suggest.
SPONSORED ADS
SPONSORED ADS
elangoas
Madrasapattinam
There is only so much you can do abt these inexpensive projectors, as the good feature rich are expensive and away from reach for many.. Retain the bill, as it is your only source of warranty.. Just incase something happens, be ready to chase the dealer and get it sorted out..
A projector at 7K, or specifically the single white LED powered lamps are limited in brightness.. So a 16ft throw distance, will further limit its brightness.. But if you are going to use it in a completely dark room then fine, else reduce the distance to 10ft.. Often these projectors have throw ratio of 1.2:1, meaning you get a bigger picture in short distance..
What are the dimension of the room, diagonal screen size you are looking for ?..
Source: Amazon FireTV Stick / Bluray Player. Usage is mostly 1080p movies. Options Checked through Forum Threads & Amazon Listings:- Egate i9, UNIC 46.
There is an Egate i9 with Android.. Suggest you get this one, as streaming movies would be easier by downloading respective apps from playstore.. You can remove firetv stick from source (or) use it in another room.. So you can leave the BR player connected to Android projector all the time..
Defnetly a DIYscreen is the inexpensive route, depending on screensize.. If you have regular screen, you can consider getting that painted.. Matte white (or) grey paint..
machinfinity
Pune
Thanks Elangoas! I plan to have an 80 inch screen for viewing. Using a Bigger size screen may result in loss of sharpness and brightness (correct me if i am wrong). Yes, i can place the projector at 10 feet distance too.
Its 19 x 20 Feet in Size. Image will be projected on 20 feet length wall.
Sure. I will check that model out, as in that case i can use the firetv stick with my LED tv in other room.
Also saw Egate P513 Model online. How much of an upgrade in picture quality will that model be over the i9 model?
If its a pretty decent upgrade then can think about it. Called egate on their phone number. They were offering both P513 & K9 for 16k.
Can't paint since i'm living in a rented flat. Will seriously do that when i move to my own place.
How much approx cost can a DIY screen take for 80-100 inch size?
elangoas
Madrasapattinam
Yes, your understanding on brightness is right.. 80 inch would be best size
Ok great.. You may as well consider map type screens which can be pinned to walls..
P513 is also powered by a single LED bulb, sure there is increase in brightness.. But not significantly brighter..
K9 for 16K.. Surprised.. Please double check with him, if they still confirm K9 is 16K, then it defnetly is a better choice over P513.. As it is powered by RGB LED bulbs.. I think K9 comes with android..
Ok fine..
Approx 4 ~ 5K (for all materials, labour)..
machinfinity
Pune
Saw this online: Map Type Screen Amazon Link
They have specified on the listing that its 4:3 ratio design, suitable for 16:9 ratio. I'm afraid whether it may reduce the screen size if used in 16:9.
But looking at the image they have shown online, it seems the practical dimensions of that screen are leaning more towards 16:9.
Noted. Thanks.
Found another option online Vivibright C80
Here are the specs:
  • Brightness: 2200 Lumens
  • Resolution: optical 1280x720.
  • Max supported resolution: 1080p.
  • Contrast ratio: 1000:1
  • Lifetime: 30,000 hours Projection Screen Size (inch): 37-110 inchs
I brought this option up over here cause the resolution output is better than egate i9 and lumen is higher. Have called them and requested a demo video. I'm willing to spend a little more if this is even a margin-able step up over i9. A distinct lack of live demos for these products is a disadvantage for someone like me who isn't well-versed in this area.
Yes you are right. Seemed to be a communication lapse on phone, that their representative gave an incorrect idea. After asking for quotation, they gave a price of 35K.
elangoas
Madrasapattinam
Most LED powered projectors in this price bracket have 1280 x 800 resolution (16:10), so good to consider a 16:9 screen..
I had used Egate P531 for abt a years time and i had uploaded pictures too.. But i used a DIY Acoustic Transparent screen (low gain screen).. With vinyl screen, brightness would be more (high gain)..
For this screen, you would approx get 85inch diagonal screen in 16:9 AR, fairly good size for the projectors..
Right, K9 is an expensive product..
Vinay2013
Gurgaon
Map type screens are inexpensive and easy to use. Decent option for a rented place. They also come in 16:9 Ratio and various sizes. You just have to dig more.
SPONSORED ADS
