coolcatric
Hi Guys,
Need some information, I am planning to buy a 42-46 LED from USA. This is what i am planning to do -
1. Buy 42"-46" LED from EBAY
2. Will try to keep the deal under 35k, as limit is 35k if i am not wrong ( i am open for refurbished / used)
3. Ask my friend (one who's traveling from US to India) to claim this under oversized baggage.
4. Put a "fragile" sticker on LED box
5. Almost all LED are Global ready & they run both 110V & 240V. Need inputs here
6. No idea on how to convert NTSC to PAL. (will use this LED for X-BOX[PAL] and Movies[.mkv] via USB)
Apart from the above, need your help on finding a good deal. You guys are local there, so need your help.
Bigger the size, lighter the weight, the better it is
Thanks in advance.
Thanks in advance.
