Cambridge Audio Stereo Amplifier under ₹18K
Wharfedale Linton Heritage Speakers
Status
Not open for further replies.
HiFiVision
Super Moderator
Cambridge Audio TOPAZ AM10 Integrated Amplifier for ₹17,760.00
The Topaz Series is the perfect setup for the Hi-Fi curious looking to invest in their first stack of separates or the existing hi-fi enthusiast, looking for both good value and high quality. Building your first component system can be an overwhelming process due to the sheer number of options out there.
Cambridge Audio has made the Topaz series straightforward and with Sound First design principles. The Topaz series is a great place to start and is guaranteed to change the way you listen to music forever. Your quest for quality audio starts here.
The AM10 gives an extra performance boost with 35 watts of power per channel. It also has an integrated phono stage for Moving Magnet cartridges which you’ll need if you want to connect your turntable.
Purchase the Cambridge Audio TOPAZ AM10 Integrated Amplifier for ₹17,760.00
Features:
  • 35 watts-per-channel power output
  • 5 x rear mounted source inputs
  • 1 x front MP3 line input
  • Integrated phono stage for turntable connection
  • Source/volume display
  • Bass and treble controls
  • Full remote control
Specifications:
  • Power Output: 35 watts (into 8 Ohms)
  • Max. Power Consumption: 260 W
  • Input Impedance: 47k ohms
  • Power amp damping factor: >50
  • Bass/Treble controls: Shelving, ultimate boost/cut; +/- 10 dB @ 100 Hz and 10 kHz
  • Dimensions: 17" wide, 3" high, and 13.4" deep
  • Weight: 5.6kg (12.3lbs)
Offer good till stocks last!
Works on 230 Volts
Official one-year manufacturers warranty valid in India
FREE Shipping to most major metros
Price includes GST
HiFiVision
Super Moderator
There is no pre out or subwoofer output.
However there is a fixed output.
sanjivnayak
Bhubaneswar
It has limited use as volume control will not work for subwoofer. But only issue is its low power output. The offer price is great. Let us wait and see if SR10 or SR20 comes with such mouth watering offer.
preth30
Kochi
I have this amplifier. Its just amazing. Great imaging, separation and sound stage. Don't worry about the low out put. Its quite enough for book shelf speakers in a medium room. Mine drives a 87 db Sonus Faber Toy bookie quite effortlessly and fantastically.
indy70
Chennai
But the AX series is out. Is it worth to wait for that ? I am sure it will be pricey, given it is cambridge.
Status
