Castle KNIGHT 2 Bookshelf Speakers
Rega
HiFiVision
Super Moderator
Castle Knight 2 Speakers
The Castle Knight 2 Speakers series achieves superb high-frequency performance using a ‘soft-dome’ tweeter which produces a more controlled performance than metal equivalents and an innovative aluminium-core voice coil which matches and even exceed the bandwidth possible from metal domes without having to worry about inherent problems.
Made from fine real-wood veneer that is sourced from sustainable timber, with the most beautiful deep-figured slices and cut from real trees. Each speaker pair being hand-finished using mirrored, book-matched veneers before being sealed and waxed in a process which takes over 5 days.
Specifications of the Castle Knight 2 Speakers
  • System 2-way bass reflex
  • Tweeter 25mm tex
  • Woofer 150mm
  • Sensitivity (db) 90
  • Impedance (ohm) 8
  • Finish: Antique Oak Veneer
  • Frequency Range (hz) 42 hz – 24 khz
  • Amplifier Power (W) 15-125
  • Dimensions (mm) 380x200x335
  • Weight (kg) 7.85 Each
