Combining / Allocating Internet Connection for Greater Speed.
deba
Kolkata
Dear All,
I have two Internet Connection one is BSNL ADSL Broadband and the other is BSNL 3G.
I want to use the bandwidth of both the connection to download and surf the Internet in Windows XP Home Edition and Windows 7 Home Edition.
Is it possible?
If the above is not possible then can I use one connection to download files and the other to surf the Internet using any web browser.
Kindly help.
Thanks! I heard that Load Balancing can be done by Software also........kindly discuss......
when the packets for the same connection between two tcp endoints take two different paths via two different ISPs, there will be heavy out-of-order packets and re-ordering due to differnt paths taken and differing latencies. this will lower the throughput and give poor performance. I would advice against it - it may be useful for torrents with some connections for a download going via one link and some on the other. Not otherwise.
The link bundling is only useful when it is terminated at the same point.
HTH
Yes you can do it completely in software, but it would take some doing.
At a high level, is this what you want to do:
1. Reserve one connection for browsing. Technicaly, http / https protocol and and file size than 100 MB (E.g. youtube videos) + VOIP ports like Google talk, Vonage, Skype
2. Use a different connection for everything else (torrents, http downloads larger than 100 MB)
100% right ...but how do I do it in Windows Xp and 7 Home Edition ?
Can I ask the Internet Explorer to use a specific connection..I have configured the BSNL 3G as the default connection but still it uses the BSNL ADSL Broadand.
Ideal way it do install a virtual machine inside windows and run a router OS (Like Vyatta) on it. Details on Vyatta.org | The Open Source Networking Community. It has a version that is designed to run on VMs so you don't have to dedicate a machine for it.
This feature works out of box on this and most other router OS.
Other way is to install an HTTP/HTTPS proxy and have it capture all http requests and ask it to use a specifc connection.
Wingate is easiest to use and supports this feature (WinGate Proxy Server).
Squid is a free proxy, but you would have to read howtos for doing that.
