DAC ifi Micro iDSD BL vs Schiit Bifrost vs Modi Multibit
mkprebou
Chennai
Guys
Need an suggestion to choose in between these DACs, ( ifi Micro iDSD BL, Schiit Bifrost & Schiit Modi Multibit) which one should I buy among these DACs. Had check with Headphone zone Bifrost currently stock not available, If you guys having suggestions on some other good Dac around 40 to 50k would be fine. Expecting a favourable response from you all.
Many
If a tad over The budget is alright do consider the Rega Dac R. It probably sounds more analog than the ones you have listed. I might know of someone selling a brand new bifrost for about 32k.
I had checked in headphone the Bifrost & Bifrost Multibit they are running out of stock . I just ordered Schiit Modi Multibit and waiting for the consignment to receive. I jus want stick down with limited budget may be after a years I might go for high end.
