Delta Step Down transformers
sunbaj
India
Hi Guys,
Wanted to know if anyone is using Delta Stepdown Transformer and the feedback if any can be provided on the same.
Thnaks
S
i am using a 2kva stepdown made by delta, its on the pricier side at some 4k i paid.. but its a trusted name and the quality is superb. have not faced any issues so far using with my denon 3310
Hi Jitubisht,
Thanks for the quick response. I actually own a Yamaha RXV 465 and the power rating for it is 274 Watt .... Should I go in for a 500 Watt Stepdown Transformer or a 750 Watt unit.
Any help in thios regards will be highly appreciated.
S
Go for 750W, you want to add BD player (50-60W) or somethng later. Or maybe even upgrade your AVR. Always good to have some extra power, unless the price difference is too much?
Hi reju,
I too own a RX-V465. I dont know all these requitements when I bought maxine 350W.
Is this 350W enough to my AMP? Will there be any issues if not enough?
I connected the Step Down Trans from a Spike (Anchor).
Any suggestions, welcome. :)
Hi Siva,
I would recomend that you add a voltage stabilizer feeding to your stepdown transformer. As for the unit you have bought if you are willing to buy a new one or if the shop from where you have bought it is willing to excahnge then I would suggest go for a higher wattage.
s
