Thanks Donivlapog,
I am a beginner to all AVR, Regarding budget I will have to invest in quality speakers set after buying AVR, the price difference between 1700H & 760H is almost 200$, I am not considering Regarding resale value, cause I will definitely use this for the next 5 years,
Regarding electrical issues, even if 760H has 110v power, can that be used in india by passing the electrical current through step down convertor, I am not an electrical expert though.
There is good deal on 760H on Costco currently, that made me consider 760H as an option, cause I have to carry the AVR by hand to India, just in case if the luggage is inspected on arrival to India, and if I am compelled to pay duty on the AVR, then 760H will attract less duty,
Also, the difference between 1700H & 760H is that 1700H is superior and has 8K heos, and 760H lacks heos, power output difference should not be a problem cause, I am going to install the system In a 250sqft media room, and the system will be confined to only media room.
I look forward for your opinion, cause it will definitely help me to make a right decision.
Thanks,
