Denon AVR-X1200W + Paradigm Cinema 100 CT
Congratulations on the purchase. Yes, suggestions will definitely be given but u need to update the dimensions of your room, whether setup is done or yet to be done, your audition experience if any and how was the buying experience and cost of the products brought by you. Do upload some pics which would help in understanding the speakers positioning. Once you tell us some more details we all would help you get more from your setup by configuring settings correctly, basic settings would be to set Bass to LFE
Crossovers to 80Hz and Subwoofer to 120Hz. Speakers (Front L/R, Center and Surr. L/R )all set to small and Subwoofer - Yes. Also you can skip all this and use audessy auto calibration. Simply follow the steps and you are done.
