Denon x3700h turns off then wakes up by itself?
xxnonamexx
New York
Just when I got everything to work correctly as far as turning the tv on and off controlling the avr as well and fixing connection to ARC. My Denon x3700h when I turn the tv off the AVR turns off but a few seconds later the AVR turns back on. Its red when its off then turns white to go back on. ANy ideas? Thanks
Are you having an OLED TV? if so it maybe the auto pixel refresh algorithm which gets ARC paired devices to switch on. That also is an indication your pixel refreshing is going on. It would happen after 4 hours of cumulative usage.
it not an OLED. I dont get after working fine for a week it has a mind of its own and turns on after I turn it off.
Here is the connection. (The photo shows it connected to the HDMI but now its in the ARC which resolved the previous issue). In reading about ARC I was wondering if the optical audio cable is needed? UPDATE: I have since removed the optical cable and so far looks like its working. Will keep an eye on it.
Hi bro,
After previous thread and this issue now, am convinced this is a software issue.
Since this is a new purchase, better and safer to consult/take it back to seller.
An s/w fix should iron out everything.
ARC and optical were connected which(optical) has been removed and now all lived happily ever after right?
So it is HDMI paired plus optical paired seperately or ARC paired alone leaving out optical. The CEC sensor will get confused if both ARC and optical is hooked. Understood now.
