The Avr willl have a pre-out. You need to connect a powered subwoofer which will have a LFE input i.e using a subwoofer cable from the avr pre-out to the sub woofer lfe input. The powerd subwoofer will have its own inbuilt amplifier to power the subwoofer.I havent unboxed my Denon X550BT yet. Today I came across this power specification of the AVR from the official website. They have mentioned 3 different poweramps, I dont understand a thing. Somebody explain please
PS: If those are the values of 5 Channels then what about the Sub
I also have the same question running in my mind. None of the brands provide the exact power ratings when all the channels of the avr is utilized. I just assume 25-30% less then the 2 channel ratingWhat would it be when it is 5ch driven with 6 ohm speakers?
Speakers will work. If u check at the speaker specs there it will be mentioned. My speakers are rated at power handling from 20-125 watts. Speakers should not be over and underpowered to their ratings.If that's the max, what would happen if connect a speaker that can drive more than 50W power? @elangoas @sud98 @Love4sound
Underpowered I agree. What you want is tons of headroom in an amp to get the best performance. If an amp has to be driven over 50% of it's volume, the distortion goes up. Like @elangoas mentioned, if they are sensitive enough, 50 watts should be plenty enough especially augmented with a powered sub woofer.Speakers will work. If u check at the speaker specs there it will be mentioned. My speakers are rated at power handling from 20-125 watts. Speakers should not be over and under powered to their ratings.
This is why folks try to get 8 ohm nominal speakers. Means, the speakers will normally hover at 8 ohm or higher (easy to drive) and only occasionally go below 8 ohms (say to 6 or 4 ohms or lower). Most amps can handle this behavior with relative ease.
When the speaker itself is rated 6 or 4 ohms, the amp has to really work hard continuously and needs oodles of power output to not get stressed out. A layman's explanation would be:
You can carry 5Kg everyday, but once in a while 25 Kg is OK. Your muscles have the reserve for these (normal amp 50-70W range)
If you have to carry 25 Kg everyday, your muscles need to be beefed up; you need to be a body builder (powerful amp 100-300W range)
A good thumb rule would be to check how much power the unit consumes. Denon X550BT max power consumption is 310W.
Take away 20% for losses and powering up other circuitry. That leaves you with about 250W to be shared between 5 channels/speakers.
As @sud98 and @elangoas stated, the available power would be 40-50Wpc (or less) depending on the design of the amp, output drive stage.
Take into account only the 8 ohm, 20-20KHz spec. This is the only true number. Others are page fillers.
50W is a decent power capability if the speakers are high sensitivity (say 88-89dB SPL or more).
As always, amp speaker match/synergy goes a long way in getting it sound right.
Sub is not powered from AVR, it has its own amp (powered sub-woofer).
In my exp, I have found this:
1. An amp that has the capacity to drive higher current (ala higher wattage rating) with a lower rated speaker is OK
2. An amp that is rated lower than what the speaker can handle and if the speaker is low sensitivity is not a good match
Headroom is when the speaker suddenly/momentarily demands more power (due to impedance dip) and the amp has the capability of sourcing this current. This is what @tuff is referring to.
Hope this helps.
Raghu
One more thing, Im getting a Taga TSW 200 for this Avr. If I connect 2 numbers of low powered sub like Yamaha SW050 to the avr, will the signals pass through uniformly? or do I need single high powered Sub to draw all the juice from the avr?
Check out the Yamaha sw300 as well. It is sold at 27000 with discounts. Rated at 250 rms nd frequency response is 20hz-160hz.Thanks. I think Im getting Taga TSW 200 from a seller in Chennai. He quoted a better price than amazon. On a second thought, Im thinking of Taga TSW 120, as the later [TSW 200] might be tooo powerful for my room [175 Sqft approx]. Anyway, Im gonna audition them both soon and make a decision.
