ukjeyaraj
My new PC is currently connected to LCD monitor using VGA and resolution is set at 1920x1080. Simultaneously I want to connect the PC with projector too. Projector(Epson EX71) has AV-in,VGA,S-Video and HDMI ports. I already have a VGA cable of 11Mts length(which is the required length). Can I use a DVI-D to VGA converter to connect the projector with PC via its DVI-D port.
Is it possible to get the display on both monitor and projector simultaneously?
Will projector get 1080p signal through DVI-D to VGA cable?
