AVR2113
Last updated:- 28.02.2018
Firmware: 1490-3169-0000-3311-1097 (DZ17-125 AVR-2113BKE2 )
1) Spotify Connect added
For more information go to :-
https://www.spotify.com/uk/connect/
2) Fixes to some internet radio preset stations
3) Other bug and improvements
Filenam:-USB_AVR-2113E2_000100580200-0011.zip
changelog of AVR2113
06.03.2014
When the customer plays the source of "DTS-HD Master Audio/96k PBR (PeakBitRate) stream", the noise occurs or the sound is not output.
The noise occurs in the play of DD+ stream of Netflix.
The product corresponded to "MSLEFT" nd "MSRIGHT" of the AMX command.
Wrong translation for AUDIO setting ""ALWAYS ON" in Dutch.
The noise occurs between tracks when a specific FLAC file is played.
The set doesn't communicate with Buffalo LinkStation (LS410/420).
In the Resume play of Last Station of Internet radio, when the connection server doesn't work, the browsing of the Internet radio cannot be done.
23.07.2013
Firmware: 1490-1169-0000-2470-5987
Swedish translation. Found a translation error.
Airplay on AV receiver does not play the sound synchronously with sound on the PC and other Airplay devices.
View photos via USB interface, the 4:3 image is stretched in width severely.
Playback multiple artist radio failed.
Preset Names of FM-Tuner can't be changed via webinterface in the range from preset number 17 to 24.
Problem with Russian Internet Radio station.
Cannot play any BBC station on the Internet Radio.
SPOTIFY-Credentials does not remain stored when changed source or unit powered off/on.
When the customer starts Remote App, the display of Remote App might become abnormal.
The PlayerView button in the NetUSB browse screen by Remote App was added. The SleepTimer setting by Remote App was added.
After the firmware is updated, the device is not found via the ios application.
07.03.2012
Firmware: 1490-1169-0000-1240-1977
The product corresponded to Gapless Playback from Mobile App.
The Picture View setting cannot be stored.
AirPlay cannot be executed while executing SlideShow.
AirPlay cannot be executed from Function other than Network.
When Main Zone is turned on GUI is not displayed, if Zone2 is on.
26.09.2012
Firmware: 1490-1119-0000-1320-0867
The product corresponded to Login from Mobile App in Spotify.
The product corresponded to High Quality Audio/Gapless Playback/ALAC (Apple Lossless Audio Codec).
When FLAC is played by iPod/USB, the Information (Audio) display in the menu displays PCM.
There is a possibility that the sound is not output from the speaker by the Auto Setup mode.
03.09.2012
Firmware: 1490-0119-0000-1410-5737
The product corresponded to Spotify.
The Spotify was added to the Network function.
The Spotify corresponded to the contents operation with Web Page.
When Spotify/Pandra/SiriusXM was played, the "Save to Favorite" function of "Option Menu" was invalidated (Favorite cannot register).
When external instrument (Apps, C4 Controller) is used for a long time, there is a possibility not to be able to control from the external instrument.
The unit shows no picture and sound via HDMI.
09.08.2012
Firmware: 1490-0168-0000-8050-2686
Various countermeasures to failures related to the "DENON Remote App".
26.04.2012
Ver0127008
Countermeasure to failure of "DENON Remote App".
Improvement of sound quality.
No major changes useful to me so mostly I will not update. Currently it's is working fine as per my needs. My major use is Blue ray/Audio CD/USB/Airplay all works with charms.... Please suggest
