spirovious
I was very happy to select xonar D2X as a soundcard for HTPC to get HD audio 5.1out.It can accept 192khz/24bit audio to do DAC job.
So I got a bluray drive to play Bluray discs(with anyDVD HD + PDVD10).
When I checked output info on PDVD,I was shocked to see 48khz/16bit audio out.That is PDVD10 was downscaling HD-audio.When I googled,I found that this is due to PAP(Protected Audio Path)& any of bluray playing SW will have to do the same.I was trying to get solution & kept trying with few media players.
With my experiement I could notice that MPCHC is the way which can do the job without PAP enabled.How?-
I also installed ffdshow,reclock.
I opened MPCHC,clicked to open file,went to stream folder & played single video file.I checked reclock to confirm that I was getting 24bit audio(PCM).
Before that I selected output as 24bit in ffdshow audio.
This was the simplest way.With same setting if I select full STREAM folder,output which I get is 16bit instead of 24bit(Like PDVD).
I then tried to play same way with PDVD10.ie.Rt.click the video file in stream folder & opened with PDVD10.It works.The only problem is how to select all video files together & rare chance to change file sequence & movie scences can be changed.ie there can be death shot showed earlier & gunshot scence after that.
http://www.hifivision.com/home-theater-pc-htpc-media-pc/14999-surprising-discovery-7.html
So I googled again & found some pages-
Full TrueHD Quality without HDMI? [Archive] - Doom9's Forum
http://www.avsforum.com/avs-vb/showthread.php?t=1118204
Playback Unmolested DTSHD-MA Audio Track via analogue - Only 30 minutes of your time - Guru3D.com Forums
ArcSoft Codec Unlocker & How To Save Audio Decoder HD Settings - Doom9's Forum
http://www.avsforum.com/avs-vb/showthread.php?t=1033822
anotherway is to rip Bluray movie with losslessflac+VC1.
You need EAC3to,Madflace,HdBrStreamExtractor,MKVmerge,MPCHC,Reclock,
arcsoft TMT(for DTS-HD decoding).
So tried these & ripped succecfully.
Most of Bluray discs has 48khz DTS HD sound & so dont know what happens with 96khz sound.
Akira is 192khz, why not other movies? - Blu-ray Forum
Blu-ray Movie Bitrates Here - Blu-ray Forum
