HDMI 2.1 cable
raj.azharuddin
India
I am from India
Can someone suggest a good hdmi 2.1 cable to buy in India?
I have below in mind:-
Cablecreation
https://amzn.eu/d/ftkN09b
Cablecreation
https://amzn.eu/d/1nOcHXA
Honeywell
https://amzn.eu/d/7YQ0xsE
Zeniq
https://amzn.eu/d/aBgWrNC.
Zeniq is a costly option.. cablecreation says certified and way cheaper but I doubt it's longevity and Performance.
Please suggest 🙏
Any certified is fine . If not cabls creation ho with ZENQ. There is Hdmi app by which we can check authenticity of the HDMI cable.
There are tons of fake and uncertified 2.1 cable out there... claiming 48Gbps, 8K, Dolbly True HD..
and so on. Never trust them. They will disappoint you for sure. Always go for a HDMI certified cable will QR code authentication. The best available in India would be the Audioquest one, but will be expensive... but a budget entry level would be from Dhavis at Amazon.in. The link is down below. They are HDMI certified and works great.
with regards
Vivek
The Honeywell one is certified. It's a good company and the cable is of very good quality. I bought one recently to connect my PC to my AVR. It is definitely better than Cable creations. I don't advise buying too expensive cables because they don't really add a lot of value. Just stick to good companies like Belkin, Honeywell, etc.
I also have a surge protector from Honeywell and its build quality is really good. It also indicates if your Earthing is working, something I haven't seen in any other surge protector. Basically the fact that Honeywell is an American company, and therefore maintains better quality control standards than Chinese and Indian companies, shows in the quality of its products.
Is HDMI 2.1 cable must to get Dolby Atmos from TV through eARC?
eARC is an implementation in 2.1 specs so yes you need a 2.1 cable for eARC support.
The older standard (ARC) can also transmit Atmos but only as a compressed Dolby Digital Plus stream. However, this may or may not work depending on the other components in the system. Only sure way of knowing is trying it out with your set of components.
Got Honeywell cable. It is certified cable and it works well.
I now get Dolby Atmos from my Mi TV apps and Fire TV 4K Max (plugged in TV) through eARC port which I was not getting from a 2.0 cable..
I Bought the BESTOR® 8K HDMI 2.1 Cable 48Gbps from Amazon, Its delivering 4K Dolby vision + dolby atmos to my Denon X3700h from my LG G1, eArc port using Netflix, Prime, Disney+ .....The price is reasonable too...Do not have an 8K tv so cannot test that
I am from India
Cablecreation
Cablecreation
Honeywell
Zeniq
Please suggest 🙏
Blue riggers are most economical and best performance.
I had more expensive HDMi but blue righer equalled it's performance at half price
