My Power Amp kept going into shutdown mode when the supply voltage went low. The area I live in notorious for power outages and voltage fluctuations.
So I've decided to get a Stabiliser for the Amp and if I buy a 6A version it will have egough capacity to hook up my other stuff on it too like - Preamp, DAC, Sky Box, etc.
The thing is I've never bought one before so in need advise on what brands to buy. Exsiting AC's have 'Everest' two smaller ones work fine but the big Digital one on the big living room AC sometimes goes loopy when the power gets really crap. Many are saying V-Guard is good? Any other makes to consider? Should I get a Digital one?
My budget is upto 10k.
