help me deciding my 3D televicsion
jammyr
trichy
I am looking for 32 inch 3D televisions... Shortlisted these two SAMSUNG 32F6100 and LG 32LB620B... Can any of you give me some guidance on which one of these to buy or any other models available with additional features?
any suggestions are welcome. May be I can think of 40 or 42 inches also. But that increases the budget, which is always a problem :D ... My budget is for 32 inches... but will think of spending more for 40 or 42 if there are any worthy features... though bigger is better, still thinking
Jammy
My experience is that 3D is only effective when it is immersive. When you have a large screen say 100 + inches and sit at say 10 feet, your arc of vision is filled with the image only. That is when 3D is most effective. On a 32 inch (or a 42, 46), i'm sorry but do not expect much.
What is your viewing distance? Considering average viewing distance of 8-10' you should go for minimum 40-42". So maybe you should wait till you can increase your budget?
