abhijitwadekar
Dear friends,
kindly help me in solving my 401 rumble issue.
Today morning I decided to service 401 which was leaking a bit of oil from the spindle. So out came the thrust plate for spindle. There was adequate oil around spindle. So I fashioned a gasket out of oil seal paper procured from automobile store. Next cleaned the thrust plate and sand papered the contact points a bit. Put the thrust plate back in place and secured it with screws.
Then I opened the motor carefully, cleaned the contact brush points lightly with sand paper and cloth. Refilled the oil sump with a few drops of oil and reassambled the motor properly.
Then mounted the turntable on 3 tennis balls feet and gave the platter a spin. It was extremely quiet and spun absolutely smoothly.
Then I adjusted the speed of tt by adjusting the screw for speed adjustment.
next I mounted the platter back again and a constant scratchy noise started coming as if the platter is touching somewhere while spinning. There was no noise without the platter.
Noise was constant even if I spun the plate and at all speed.
the speed was also not stable and kept varying all the time.
I have tried adjusting the speed but nothing is helping.
Dear friends please help me in finding the fault.
Thanking you in advance for all your advice.
regards, Abhijit
regards, Abhijit
