Hi all,
A digital newbie here. Please be gentle
I have done quiet a lot of reading on the various setups folks have here. But most of the digital chain seems to be too long and complicated to fit into my space. Besides, iam too dumb at computers to consider the various DIY solutions available out there. And I do have lots of doubts regarding the various means of connecting digital sources - usb, optical, co-axial etc.
If i do go for a roon setup, then i will down sample everything to 24/92 as that is what my amp accepts for its inbuilt dac. And considering that the 4 types of digital inputs on my amp - Co-axial, hdmi, optical & aes-ebu all accept 24/92 samples, which would sound the best with the minimal faffing around
1. Since i will not be using usb at all, will adding external clocks like the Mutec MC3+ still make a difference in sound quality.
2. Ideally my plan was to add a bluesound node 2 via co-axial and call it a day. This will add a roon end point, as well as have lots of streaming options in-built ( I do have a simple NAS ).
3. A second option would be to add a audio alchemy dmp-1 or Metrum acoustics AMORE via the aes-ebu to the amp. Both of these are roon end points with aes-ebu outs.
4. I presently use a CCA via optical out to the chord dac. Will adding the chromecast 2 via hdmi give better sonic results, than a CCA via optical in on my new amp.
Thanks for your time and suggestions.
