Dantedanger
Hi there,
First post on this forum and I'd really appreciate some advice. I've just picked up my first 5.1 surround sound speakers set - Yamaha NS-P20 :
Yamaha NS-P20
I've been trying to select an amp to match them up with and have had a look at the following Huyandai :
Huyandai
Do you think this amp would work okay with the speakers? I've read a little about this and I think you need to match up the wattage with on both the amps and speakers, but I really am not sure. Any advice or guidance on the suitability of this would be appreciated. If this amp isnt suitable, I'd really appreciate recommending one that would, budget is around 100 - 200. I appreciate this is a pretty low budget, but its my first system and I am really just trying to learn about it.
Really appreciate any advice and guidance,
Many thanks in advance,
Best,
Lee
Yamaha NS-P20
Huyandai
Best,
Lee
