Hi All,
Need help, I am having a problem with my music cum htpc. Presently I listen to music via foobar 1.1.15 --> USB - ODAC --> Denon 1911 AVR
For that last 1 or two weeks I am noticing a problem that if I play audio via ODAC every 4 or 6 secs the audio gets stuck for 1 sec and then plays normally. Here is what all I have tried so far, btw when the auio stops coming momentarily the file / player continues to play normally though making it a momentary miss of audio and not a momentary stop.
First I thought it was a problem with Foobar 1.1.13 then upgraded it to 1.1.15 but problem is still there.
Then I thought it to be network issue so manually copied a song file on to local hard drive, then played it, same issue.
Then I went to Manage Sound Device (Win 7) on HTPC and reconfigured setting of ODAC (currently set at 24 / 96). Still same issue.
Then I installed vlc player and selected ODAC as output device. Same problem persisted (thus not a problem with foobar).
Then I thought that it might me a problem with the USB port on the HTPC, tried switching to different ports on the htpc (front and rear), still same problem.
Got scared whether it is a ODAC problem , found nothing similar on the net. So connected ODAC to my sony vaio laptop. Thank God everything played well. So it is not a problem with the ODAC.
On my htpc everything works fine with XBMC outputting over HDMI to AVR.
Also tried in foobar with various output options like WASAPI push, WASAP Event, Direct Sound but same problem persists.
So I think it has something to do with the USB of the HTPC.
Can it be that there is something with Windows driver for USB?
Any inputs anyone?
Thanks in advance
Any inputs anyone?
Thanks in advance
