Help with Klipsch R-12SW
buzzaro
Ahmedabad
So, I just received the Klipsch subwoofer from the USA.
I am 99.99% sure it doesn't require a stepdown voltage transformer, but I still thought I would ask other people before turning it on.
The back panel shows 100-240 V 50/60 Hz.
I've been using the R-10SW since 4 years and have it plugged directly to the mains outlet without any transformer.
So, go ahead and use it as is. No need to worry
I was worried as there is no mention of any switch or power mains in the manual.
Did you buy yours from India or USA?
The second picture clearly shows it can be used in 240v configuration. Older models of klipsch was 110volt but now everything is manufactured in China so it is 110volt/240v
Through Rahul on TechEnclave. If you are familar with TechEnclave, search for USA shipping on that forum. The service is temporarily on halt but it may start soon.
