Hi from a Vishal,guilty 4 a long question,thank u in anticipation all fellow members
vdpandit
hi to all of u, seek all sound gurus blessings
in the beginning was the word , and the word was with god and the word was god.
hope that makes the importance of sound and word, clear enough
a. Budget : I HAVE recently purchased LG 42PW450 42 inches 3D Plasma TV. MRP Rs. 69990 Zero Margin Price Rs40000/-
my budjet is 25000 + up to 30k including all cables, etc. which includes all speakers, receiver, amp, etc, basically looking at , Philips 3751 or onkyo 3400 hts (HTIB) ; it should be 3D compatible and provision for attaching a blu ray player in future( I apologise for my lack of technical knowledge, so some of my queries may look absurd)
b. Listening tastes : my priority is MOVIES 70 : MUSIC 30 , Indian and western instrumental, classical vocal, original sufi, and some fun songs like Dhoom series for parties occasionally.
c. Listening area : MY living room has 20 feet by 20 feet hall with two columns in between , + sliding glass window of 16 feet width by 6 feet height. There are four doors spread opposite the big sliding window. Flooring is vitrified, I have a false ceiling, + dining table of 8 seats rectangular, big sofa set of 3+2+1 very large in size. One drawback is due to huge size , airconditioning is out of my budget . My Distance from screen is adjustable between 12 feet to 15 feet. To my couch .
d. Systems already selected
My shortlisted system are
1) onkyo 3400 hts,
Or
2) one out of the following Philips systems
- Hts 3571 -1200 watt , 2009 model- 19990/- ,
- Hts 5550 25990/- 3d angled speaker, double bass tech , 3d angled, 1200watt,
- Hts 5540 23990 3d angled speaker 1200 watt
- HTS 5530- 16990/- , 3d angled speaker. 1000 watt
arena worli- motimahal, 202, dr.annie.beasent, road, Mumbai 18, 24934400.
Our ex-moderator |Bullram, has praised 3571 , so kind of inclined towards brand Philips.
Or
As per our senior expert advice
or
( some dealer in mumbai suggested me SCS 140 5.1 Simply Cinema Speaker System
Product Description
The JBL Cinesystem 133 Home Theater package includes harman/kardon AVR133 reciever and
JBL SCS140, 5.1 Home Cinema System.
Our smallest satellites pack a punch that will really surprise you. Crisp, clear and really easy to
set up.
Harman/Kardon AVR133:
- Front USB 2.0 port for Audio Decoding from Memory Stick
- Dolby Digital & Pro Logic II, DTS 5.1
- MP3 & WMA Audio Decoding
- Matrix Headphone, Matrix Surround & Virtual Surround Decoding
- 5 Channel Stereo DSP Mode
- Front Panel Inputs, Audio(L/R) & Composite Video
- Main & Remote Speaker Switching (Speaker A+B)
- 3 Digital Inputs, 2Coax & 1 Optical
- HDTV-Compatible
- Video Inputs 93) /Outputs (1), Rear panel
- 5.1 Channel Direct Inputs
- Audio Inputs (CD & Tape), Tape Audio Outputs
- FM/AM Tuning, 30 Presets
JBL SCS 140: 5.1 Home Cinema System
The 5.1 SCS 140 features four elegant compact satellite speakers and a matching center. All speakers are videoshielded
allowing positioning close to a TV monitor. These are combined with an active subwoofer featuring a
powerful 100 W amplifier. Simply combine with an AV receiver and DVD player to enjoy the latest Hollywood
movie in stunning 5.1 surround sound. The long-throw 8 drive unit in the subwoofer will give you the bass impact
you need to make the most of your movie sound.
Specification
Satellite Speakers Center Speaker
Frequency Response (-6dB): 120Hz 20kHz 120Hz 20kHz
Sensitivity (2.83V/1m): 86dB 88dB
Impedance: 4 Ohm Nominal 4 Ohm Nominal
Recommended Amplifier Power: 10 50 Watts RMS 10 50 Watts RMS
High Frequency Driver: 12mm Titanium Laminate 12mm Titanium Laminate
Midrange 75mm Paper Cone Dual 75mm Paper Cone
111 81 x 95 mm 83 x 194 x 95 mm
0.5kg per single unit 0.85kg Silver Gray Silver Gray
Subwoofer
Low Frequency Cut-off: 35Hz
High Frequency Cut-off: 160Hz
Built-in Power Amplifier: 100 Watts RMS
Low Frequency Driver: Long Throw 200mm Paper Cone
Dimensions (H x W x D): 410 x 280 x 376 mm (including feet)
Weight: 12.7kg per single unit
Color: Black/Silver Gray
Jbl CINEMA 300 is one more option for speakers
Compact speakers for larger-than-life home theatre sound
HARMAN Consumer, Inc.
8500 Balboa Boulevard, Northridge, CA 91329 USA
JBL - JBL Home Audio - JBL Car Audio - JBL Marine Audio - JBL Home Theater, Theater Systems, Speakers, Stereo, Electronics, Surround Sound Systems
2011 HARMAN International Industries, Incorporated. All rights reserved. JBL is a trademark of HARMAN International
Industries, Incorporated, registered in the United States and/or other countries. PolyPlas is a trademark of HARMAN
Features, specifications and appearance are subject to change without notice.
TECHNICAL SPECIFICATIONS (continued)
Cinema 300 Centre Speaker:
Low-Frequency Transducers: Dual 3" (75mm) PolyPlas cones, video-shielded
High-Frequency Transducer: 1" (25mm) titanium-laminate dome, video-shielded
Recommended Power Handling: 100 watts
Nominal Impedance: 8 ohms
Sensitivity (2.83V/1m): 89dB
Crossover Frequency: 3.7kHz
Enclosure Type: Sealed
Connector Type: Push-spring terminal
Dimensions including stands
(H x W x D): 4-7/8" x 12" x 3-3/8" (124mm x 305mm x 86mm)
Weight: 3.2 lb (1.45kg)
Sub 140P Subwoofer:
Low-Frequency Transducer: 8" down-firing cone
Enclosure Type: Ported (down-firing)
Amplifier Power: 150 watts
Frequency Response: 32Hz150Hz
Crossover Frequency: 50Hz200Hz (variable)
Controls: Volume, crossover frequency, phase
Connections: Left and right RCA line-level inputs, LFE inputs
Power Requirement: 120V/60Hz, 150W (US); 220V/50Hz, 150W (EU)
Power Consumption: <1W (8mA@120V) standby; 300W (2.5A@120V) peak
Dimensions (W x H x D): 18-7/8" x 14-3/8" x 14-3/8" (479mm x 365mm x 365mm)
Weight: 22 lb (10kg)
HIGHLIGHTS
Engineered to work as a system Components are designed to work together for optimal
performance
Voice-matched speakers The four identical satellites are voice-matched to the centre for
consistent sound from speaker to speaker, creating a more realistic 360-degree soundstage
Dual midrange centre speaker The Cinema 300 centre speaker employs dual midrange drivers
for clear, distinct movie dialogue
150-watt powered subwoofer Fast-moving 8-inch (200mm) woofer delivers realistic, highimpact
bass
Down-firing bass driver Unlike conventional front-firing drivers, the SUB 140P Subwoofer
interacts with the floor rather than nearby walls for improved bass quality
Distinctive JBL Weave design Dynamic, one-of-a-kind look
Features
Video-shielded speakers may be placed near TV monitor without magnetic interference
CEA-colour-coded speaker wires simplify connections
Subwoofer controls permit easy tuning of bass performance for room acoustics and personal
preferences
Subwoofer line and LFE inputs ensure noise-free connections to virtually any A/V receiver
Subwoofer auto on/off for maximum energy savings
Low (less than 1 watt) subwoofer standby power consumption meets new European guidelines
Built-in keyholes for easy wall-mounting of satellites and centre speaker
All speaker wires and connecting cables are included
e. : I stay in Mumbai , In goregaon , that is close to andheri , western suburbs, but open to go any where for a good deal.
Few queries
What is -
- is dolby prologic iix necessary or prologic ii is enough
- Video Signal OUT (HDMI) Upscale 720p/1080i for DVD
- Composite
- component
Re: Hi from a Vishal,guilty 4 a long question,thank u in anticipation all fellow memb
why dont you audition some 'real' systems instead of these stupid htibs. search on these forums and get addresses for dealers in mumbai. If you go for htibs, you will soon be bitten by the upgraditis bug. if you cant afford a full ht system, just get an avr and main speakers for the time being and add more speakers when you can.
Welcome to HFV...
I saw Denon HTS 390 for Rs.25k + 10% discount.The Black one is new on Display & Golden is there for long time @ Croma Mulund.
Welcome to HFV
PLII processing is for systems up to 5.1 speakers. It converts 2-channel material to 5 channels.
PLIIx processing is for systems up 7.1 speakers. It converts 2-channel and 5.1-channel material to 7.1 channels.
+1 to this! ..
For the space you have .. just get a good amp or even a basic amp (denon1611 or 1311) and get Floor standers for now and upgrade from there. The Denon's are going cheap now .. at around 17K for the 1311 and 22-23K for the 1611.
The Jamo 606 is around 28K .. + cables 2k .. will be a great start .. :D
Think about it.. Welcome to the confusion, perseverance, patience and excitement that is HFV:D ..
Cheers!
Welcome to hfv.
Since your maximum budget is 30k and your preference is movies over music, you can definitely go for the onkyo 3400 model. It is 3d capable and supports hd audio. Another option is to buy an avr like denon 1611 now and upgrade step by step.
