during high action scenes the volume suddenly goes high in my system, my AVR IS pioneer VSX 1131, i cant see any setting in my avr to prevent this, any help will be appreciated
I m also experiencing similar
What is the modrl number of your Yamaha.I have yamaha avr. Which setting will prevent sudden spikes
If you have a pdf copy of the manual, search for terms like loudness, volume level control, or dynamic range or dynamic volume.during high action scenes the volume suddenly goes high in my system, my AVR IS pioneer VSX 1131, i cant see any setting in my avr to prevent this, any help will be appreciated
Hi,during high action scenes the volume suddenly goes high in my system, my AVR IS pioneer VSX 1131, i cant see any setting in my avr to prevent this, any help will be appreciated
yes exactly i m speaking the same, but it gets too lound too be tolerable, i hv tried maccc but then sound is not upto my liking so macc is off and set the sound settings manuallyWhat do you actually mean by sudden volume spikes ? Does it mean, that for chance, you are hearing at a volume level of 70 and suddenly the volume spikes cause it to go to 75 ? Do you mean that ?
If not, then its completely normal, coz action scenes like gunshots, car crash, explosions are very loud in real life and they will sound very loud in a HT setup. It has to be like that.
Most people hate Dynamic Volume, as it feels like hearing a highly compressed audio, but give it a try if you like.
I think that is the dynamics of the sound .For certain scenes it is required ...say example Bomb explosions/Shot gun firing etc.,during high action scenes the volume suddenly goes high in my system, my AVR IS pioneer VSX 1131, i cant see any setting in my avr to prevent this, any help will be appreciated
I second this. If Action scenes are louder than dialogues then your system is doing the right thing. Most movies are mastered like thisWhat do you actually mean by sudden volume spikes ? Does it mean, that for chance, you are hearing at a volume level of 70 and suddenly the volume spikes cause it to go to 75 ? Do you mean that ?
not tired it will try n let u know, but i dont think there is option like that in settingsDid you try the A.DRC ? Its under " options" menu. Locate it and set it to "ON"
You can use it if you really want to suppress effects.Else the scene may not be enjoyable as intended to sound in original recording.not tired it will try n let u know, but i dont think there is option like that in settings
Usually doesn't happen when using remote control. I had sr5006 for short period and after 1hr of uses, that issue would come. Must be heat causing malfunction of volume controlAny solution guys i have started facing this issue, my amp is denon avc a1hd and while I raise the volume one by one it increases and jumps like 12 to 15 db for eg i am at -27 and the scene is going and i raise the volume as I want to go up a little and while doing so it gets a jump and the sound increases which is also scary i had to put the amp off right away to save speakers and amp too
Help guys
