Hi HiFivision members,
I'm setting up a home theatre (again ) in my new place using my existing equipment. Currently in process of procuring the acoustic materials and found one source - bajaao.com
I wanted to confirm is it ok if I just use strong glue to stick the acoustic material sheet on the walls instead of using wooden frame panels. I want to avoid any furniture related activities and hence wanted to know?
If glue is not good option, can i used thin ply 3mm sheets to screw to the wall and then over the play I can stick the acoustic sheets?
I have read some websites where people have stuck the sheets but I wanted to confirm from folks here too.
Neo
Neo
