How to Rip and play original blu-ray 3d with dts-master audio hd
pradhan
Haridwar/Bangalore
I have few original 3d blue ray but i would like to store in my 3tb wd live nas storage.....i can rip using makemke but i am unable to play 3d rip title ...after ripping my playback is always in 2d format....Is their any setting which can help me 3D play back...while ripping i have selected 2d & 3d track
i have powerdvd 13,vlc ,xbmc installed on my asus laptop....my asus laptop is i5 with 3d playback capability ....I am using it to play original 3d blue ray....
However in orignal blu-ray playback if i choose dts-master hd it start to stutter but i can easily play dts....Please suggest some solution...
MakeMKV uses a format called mvc 3d for 3d files. This format is not recognized by all players. Some says stereoscopic player can play it, though I haven't tested it. Your best option is to store the disks as ISO format.
Check the supported audio formats in your hdmi audio properties. Is hd audio listed there? Also if you are experiencing the stutter only in xbmc then set the playback and passthrough devices to wasapi hdmi in xbmc system settings.
