Hi All,
Need some advice :
I already have 2 DVD players
1. LG DV356-P
2. Phillips 727K
It seems both of these would support 5.1 Speaker system.
So, I need to buy only a speaker system ?
If yes, then what is my best choices for the same ? and which of the above DVD player I should use ?
If the above option is not feasible and Receiver is needed, I was looking at YHT-196 as an alternative. What difference will i find in a HT with or without a AV Receiver ?
Need some advice :
1. LG DV356-P
2. Phillips 727K
