Hey Friends,
I want to have a good Home Theater system as per below details
1) Use - Music and Movies (with Plasma TV)
2) Budget - Rs 50,000 - 1 Lakh
3) Homework - Still exploring details on various sites. Initially wanted to have a Bose Lifestyle system, then on various sites, got to know that I am naive and there are far better options available (Klipshe, Denon, Boston, Polk Audio.....)
4) Location - Ultimately to be used in Ludhiana
5) Sourcing options - Ludhiana , New Delhi, USA (If get cheaper in New York)
6) Help needed from you experts
6.a) Want to understand what are various components of a home theater with their importance.
6.b) In the price range as mentioned above, is a HTIB a better option or should I try to build one.
6.c) If I try to build one, will it be cheaper (or a better system in same price). If yes, are these individual components available in USA (I often travel to NY) at bhphotovideo.com or JR.com, as it may be cheaper in USA.
6.d) Where can I buy, explore options in Ludhiana / New Delhi.
6.e) Which system / Configuration you suggest as experts.
6.f) How much should I pay for individual components / HTIB to have a fair deal.
THANKS. I LOOK FORWARD TO YOUR ADVICE.
