I had the opportunity to spend some time with iFi-Audio's iDAC this weekend. A friend is bringing all of iFi-Audio's products to India. He'd mentioned to me that one example each of a few of the products had arrived last week. I asked him if I could have the iDAC for a few days so I could listen to it, just for fun. I thought I might as well share my impressions with the rest of you folks.
iFi-Audio is a sub-division of AMR (Abbingdon Music Research), UK. iFI's products all enjoy technology that has trickled down from the far more expensive products of AMR.
Unboxing
Whats in the Box
1) iFi iDAC
2) A-B USB Cable
3) 2 RCA to 2 RCA Cable
3) Stick-on gel footers (4 nos)
4) Warranty Card
Physical Impressions
- All aluminium body. Solidly built. No creaks or gaping seams. Nicely textured body = No fingerprints!
- Compact. Only 17.1 x 6.7 x 2.8 cms.
- Quality connectors.
- Solid knob with excellent feel (for the headphone amp).
- 3.5mm socket for headphones. NOT a 6.35mm (1/4 in) socket.
- 3 led indicators on top. (Receiving power, connected to the computer, giving output).
- Single input: USB only.
- RCA outputs, headphone output (3.5mm), and headphone amp volume knob on one side of the body, and the USB input on the other side of the body. This does make for a bit of a cable dressing challenge (with cables coming out of both ends), but I guess the designers had their reasons to keep the input side and the output side separate.
Feature highlights
- 24bit/192khz DAC
- ESS Sabre Hyperstream chipset
- Asynchronous USB, with tech trickled down from AMRs $5000 AMR DP-777 DAC, resulting in super-low jitter and bit perfect technology, as per iFi.
- 150mW Headphone Amp
- 3 dedicated internal power supplies & discrete analog stage, as per iFi.
- Separate power supply (as in power brick/wall wart) NOT necessary. (A dedicated USB power supply is available separately from iFi, to improve upon the iDAC).
- Driver not required for Mac OSX or Linux. Driver necessary (download from iFi-audio.com) for Windows (required for XP and upwards).
- Detailed tech specs are available here: iFi-audio iDAC
Setup
The iDAC is quite easy to setup. Just plug in the supplied USB cable into the iDAC and into the computer, connect the RCA interconnects, and we're good to go. The iDAC does not need an external power supply or wall wart, and that is a very convenient thing - one less set of wires to manage, one less power socket needed!
Note: iFi has a dedicated USB power supply iUSB Power) and a special USB cable (Gemini USB Cable) to improve upon the iDAC, but those had been sent to somebody for evaluation, so I could not try the iDAC with those.
In the case of a windows-based machine (XP and upwards) we have to download and install a driver from the iFi website. MAC OS X and Linux don't need drivers. The driver install went fairly smoothly: The box says we should plug in the iDAC only after installing the driver, but the installation program asked me to plug in the iDAC in the middle of the installation. After that, it said the device was not installed. I unplugged the iDAC and plugged it back in, and the installation completed smoothly. I did not need to restart, though the note on the box said a reboot would be required. Maybe they've improved on the driver (or they were referring to machines that run Win XP). I'm something of a worrier, so restarted anyway, just in case.
My Music PC runs on Windows 7 Home Basic (32 bit). The OS and JRiver Media Center v18 are loaded on a 64GB OCZ Vector 3 SSD. The music is stored on an internal 3.5" 3TB WD Green HDD. The machine has an AMD E350 fanless motherboard with a 4GB stick of RAM in it (only 3GB is used, as it runs a 32 bit OS). Cabinet fans are disabled. There are no programs other than JRMC v18 installed. There is no anti-virus installed (The machine is sand-boxed: no network, no internet). The usual basic tweaks have been made to the OS to make it function well as a Music PC.
The iDAC was connected to a USB2 Port in the rear of the PC (the pair of the port was left unused) using the USB A-B Cable that came in the box.
Continued in the next post...
Unboxing
Whats in the Box
1) iFi iDAC
2) A-B USB Cable
4) Warranty Card
Feature highlights
- 24bit/192khz DAC
Setup
