integrated stereo amplifier vs pre-power(multichannel) for hifi
subabu2002
ERODE , tamil nadu
hello everybody,
i have planning to buy Tannoy DC6T SE for music.. for this i must need bit powerful amp for better sound..
also,planning to buy integra seperate power\pre combo for HT ..
but still confused to get new integrated amp for Tannoy...
i dont wish to invest heavy amount again for musical integrated amplifier..
my question is ,
do pre/power combo (multichannel) will work well musical sound like dedicated integrated amplifier?
for music , does integrated amp is better than pre/power(multichannel) combo?
or power/pre (multichannel) combo will do better as integrated stereo amp.?
thanks in advance
suresh babu
perhaps im mistaken but from your post it seems that you a little unclear on the terminology
a stereo amplifier is a 2 channel amplifier. a multichannel is a surround sound amplifier.
both of them come as integrated and separates. an integrated amplifier consists of a pre amp and a power amp in one body. separates is when the pre amp and power amp are housed in separate bodies.
a pre / power separate is generally better than an integrated amp but is also quite a bit more expensive. esp at the level of system you are talking about, imo it will not be worth the extra money you spend on it.
at a given budget, a stereo amp will generally be better in sound quality than a surround sound / multichannel amp mainly because it has to power only 2 speakers instead of 6.
so if youre going for a stereo set up with the set up speakers mentioned above imo go for an integrated stereo amplifier
Hi subabu2002
Whats the budget you are willing to spend on a integrated stereo amp or AVR? Once we know this, we can advise you better...
