IWAI Speakers - Usage in DIY Home theater 5.1
Non_Techie
Hyderabad
Firstly i will give the details fo the prices that are by shared by IWAI marketing team...
3" ALU Woofer 8? 20W Rs.275/-
3" Woofer 8? 20W SHILDED Rs. 155/-
3"Woofer 4? 20W Rs.300/-
4" Woofer 8? 25W Rs.330/-
5 Sub- Woofer 8? 40W Rs.350/-
5" WOOFER 4? 40W Rs.425/-
6" Sub- Woofer 4? 40W Rs.400/-
6" SUB WOOFER 4? 125W Rs.900/-
6" Sub- Woofer 8? 75W Rs.400/-
8" Sub- Woofer 4? 125W Rs.1100/-
D21 AN RD FP Rs.270/-
D21FN RD FP Rs. 170/-
D21SN RDFP Rs.210/-
D22 ALU MG T-Yoke Type Rs.1400/-
D27 AN LFS Rs.400/-
D27 SN CRFP Rs.360/-
D27 TN LFS RDFP Rs.600/-
D27SN CAR Rs.650/-
D27SN LFS CRFP Rs.400/-
Tweeters :
D21SN RDFP Rs.210/-
D27 AN LFS Rs.400/-
D27SN CAR Rs.650/-
Terms:-
All Price are basic.
Taxes as per below mention .
Ex. Duty.-- 10.3%
CST-- 12.5%
Freight: To your Account
Octroi (if any): To Your Account.
When i see the prices...i am really getting tempted to try DIY 5.1.
Yes..yes...yes...then what ...??????
My question is if i use the specifications on the below page..
IWAI :::::: unique solution for audio system ::::::
(this is just an example basing on this i want to build others too)
can i be able to build speaker box...do i need any thing extra...also...what
software would help me to design my speaker cabinet.
And also need detail procedure to build a Cross over.
Thanks,
Non_Techie
Non_Techie,
The last I enquired with IWAI, they replied they were not interested in retail quantities. Did you contact any of their retailers? BTW, where are you based?
Hi GR...i asked the IWAI guys they are willing to sell the quantities..in retail as well...i am at chennai...
Thats great,
Just pick the drivers and get going. Build 3 way for front channels and 2 way for the rest. My driver choices would be dome tweeter (for all Ts), 3" alu driver (for all Ms) and 8" for woofers. The driver sizes I mentioned enable you to have a big overlap in the transition region which helps you to integrate them well.
Fronts: 3way MTMWW,
Center: 2 way MTM
Surrounds: 2way TM
Start by doing a stereo setup, you could start with the surrounds first. Once you have success there, you could go for the center followed by the fronts.
If you get it right, You could enjoy such a system for years to come. ;)
Good Luck,
Goldy
Hello...GR...
Great...this what i expect out of hifivision..yes..
I am going to order them..
Thanks a lot...
yahoo:
Goldy..one moment...
where are you located in Hyderabad.....
I used to stay in Tarnaka...
GR..one more thing...
did you see this on ebay.in...
will it be worthful in experimenting this....eBay India: LA4440 Audio amplifier kit Double IC 12V 38Watt RMS O/P (item 170605536421 end time 21-Mar-2011 14:03:54 IST)
Rs..300..i will just stop moving out one sunday..i will save money to expriment
this..what do you say...
If you say ok..i will order immdtly..and try to assemble my own cabinet..
Non-tcheni...
Goldy...hi...can you just give me example as to how to build the box enclosure using the specs provided by iwai at their site...
iwai speakers
specs good to see .have to build first .have u taken iwai speakers ?i m a tech guy i will give u the box details.i m at suchitra hyd find me by phoning 9666678606 .guru prasad
Any update on operations of IWAI? Do they deal with retail orders or is it just wholesale for them?
ok thats great you need to transfer the amount first then they will make it also it would take some time I think might be two weeks
