Jamo Cornet 95? ARCHIVE unfold
businessbysaud
pakistan
Just got a pair of JAMO speakers that i can't get any information about.
would be helpful what these speakers are. The only closest similar product has been JAMO cornet 90iv
I emailed Jamo support only to get this reply:-
pictures of the speakers attached:
WhatsApp Image 2022-10-05 at 9.48.26 PM.jpegWhatsApp Image 2022-10-05 at 9.48.26 PM (1).jpeg
Speaker systems from the Danish manufacturer Jamo with the name Cornet were mid-range speakers, but with a fairly good sound considering their price. They were made in Denmark.
The 1994 Cornet series is a series that had a timeless design and decent sound. The massively processed sound box is made of MDF boards, which, thanks to their sound-absorbing properties, ensure clear sound reproduction.
The series consists of six speakers. From small compact two-way speakers to the largest three-way speakers with an 8-inch woofer, mid-range speaker and dome tweeter.
The Cornet has a specially developed bass driver with a high-performance coil that can withstand heavy loads. The soft dome tweeter provides an airy and transparent sound. Thanks to the magnetic oil in the air gap, the speaker system can handle even large power peaks.
Speakers of the Corner series are equipped with massive gold-plated connectors that enable universal connection. It is possible to connect powerful cables directly and it is also possible to connect with banana plugs.
In 1994, the Cornet series included the following types:
  • CORNET 20 IV
  • CORNET 30 IV
  • CORNET 40 IV
  • CORNET 60 IV
  • CORNET 70 IV
  • CORNET 90 IV / 95
THE CAVE​
Cornet 90 IV / 95​
Typ columnar
Nominal Impedance 4 ohm
Long-term performance 140 W
Short term performance 200 W
rear bass reflex
Characteristic sensitivity (2.8 V / 1 m) 91 dB
Frequency band 40 - 20 000 Hz
Bass speaker 2 x 203 mm
Center speaker 133 mm
Tweeter DOME 25 mm
Turnout Yes
Crossover crossover frequency 800 / 4000 Hz
Number of bands 3
Dimensions (hxwxh) in mm 870 x 255 x 266 mm
Internal volume (l) 59
Weight (kg) 13,7
Years of production 1994
Cena
Color version black / mahogany
