For Sale Linear power supply AC to DC 12v 5.5 Amp for hifi DAC, Router, DTH
Wharfedale Diamond 12 Series
Status
Not open for further replies.
gowmara
Coimbatore
Package includes,
Power supply
Power adapter
Dc cable
Quoting price:9.5k
Months old:6
Shipping all over India at buyers cost. Fully functional.
Connect it to get good noise free, good bass sound in speakers. Good video quality.
Introduction:
Input voltage: AC230V
Output voltage: DC 12V 5.5 Amp
Front panel: Black
Dimensions: Width 210mm * High 70mm * Heep 257mm
Transformer Power : 100VA
Weight: about 4.5kg
Power Polarity: inner"+" external"-"
DC Head Size: Outer diameter 5.5mm, internal diameter 2.1mm
Technical highlights
All-discrete topology.
Single-pass, series regulator design.
No IC (integrated circuits) are used. This allows complete design control over all operating points and parameters for superior performance.
Low noise, high PSRR
A constant-current source feeds a zener diode as a stable voltage reference. A low-pass filter (with a corner frequency of 1.6Hz) prevents zener
noise from being introduced into the error amplifier. This is an effective yet lower-cost alternative to expensive voltage reference ICs. The low-pass
filter also provides a soft-start characteristic.
The output noise (unloaded) is less than 13µV at 24VDC output (measured using a Tangent LNMP (low-noise measurement preamplifier) and a Fluke
187 50000-count DMM in ACmV mode). The output noise is even less when the output voltage is lower. This is much better than the noise of an IC
regulator based PSU tested under identical conditions.
The error amplifier is a discrete implementation of an opamp with a high open-loop gain of 102.5dB. The voltage supply to the error amplifier is isolated
with capacitance multipliers to boost its PSRR (power supply rejection ratio). This greatly improves the line regulation performance of the PSU.
A long-tailed pair differential amplifier with current mirror and constant current source forms the first stage of the error amplifier. The second stage is the
voltage amplification stage (VAS), also with constant current source load. The 3rd stage is comprised of the power MOSFET output devices configured as a
source follower.
High-current MOSFET pass transistors
Two paralleled high-current, highly reliable MOSFETs (rated at 18A each) serve as the "pass" transistor.
The high current rating provides a very high safety headroom against overcurrent damage.
The use of paralleled MOSFETs divides the heat dissipation, simplifying thermal management. Onboard heatsinks can be used which would allow the this PSU
to supply up to 1A continuous (with much higher peak currents). More sustained currents are possible by using larger, offboard heatsinks.
The negative temperature coefficient of MOSFETs prevents damaging thermal-runaway conditions that may plague conventional BJT devices.
No current-limiting.
The main purpose:
Upgrade XMOS CM6631 TE8802L etc. USB interface DC power supply
Various DC5V power supply set-top boxes, routers and other digital devices
A variety of USB-powered digital equipment, charging your mobile phone
A variety of digital devices such as amp/ DAC/HIFI audio player
BUYING, SELLING or TRADING indicates your automatic and mandatory acceptance of HiFiVISION.COM Trading Rules and Guidelines!
Do not blindly trust every seller or buyer! Protect yourself by following the below safe trading tips.
Safety Tips
For Buyers
  1. Always meet the seller at a safe location and inspect the item before purchasing. Following this one rule will help you avoid most scams.
  2. Watch out for unrealistic offers. If it appears too good to be true, it probably is. Unrealistic offers are used to motivate purchasers to make hasty decisions.
  3. Always verify the seller's credentials. Ask the seller to provide a photo ID and proof of address.
  4. Ensure that the product you are buying is not stolen or fake. Always ask for a purchase invoice.
  5. The best way to transact is to collect the item and pay at the same time. Never transfer funds or use a debit/credit/atm card to pay someone you do not know before collecting an item.
  6. Ask for clear information on condition of the item, price, payment and delivery method.
  7. Use only those payment methods that you trust and are familiar with. Never give out your financial information.
  8. It is recommended to purchase items directly from the seller.
  9. Always test the functioning of the item before purchase.
  10. Do your research on comparative prices for the product.
For Sellers
  1. Try to take the full payment at the time of the delivery. Remember to use a safe location to meet.
  2. Watch out for fake currency and money orders. Be aware that banks will not honour fake currency/money order and will hold you responsible for it.
  3. Verify the buyer’s credentials if necessary.
  4. Ensure that your product meets the features you list in your ad to avoid any misunderstanding with the buyer.
  5. It is your responsibility to prove that the product you are selling is genuine and not stolen by providing the necessary proof of purchase.
  6. Do not share your financial information except the one required for payment.
Robert Bose
Bangalore India
Dear Sir
is it fixed 12V or is it adjustable
do you have the link for the Chinese manufacturer who makes it
assuming all the technical info you posted is from that Website
is there any brand name for the product ?
Robert Bose
gowmara
Coimbatore
Brand zerozone, it is fixed for 12v, but you can connect separate step down transformer if you need less than 12. It cost around rs.300. I connected 12v, 5v at same instance
Status
